Automatic Trans. Problems
Old Mar 15, 2003 | 10:19 AM
TransAm2k4's Avatar
Unhappy Automatic Trans. Problems
I have a really bad problem with my tranny. It won't shift to 3rd. I know it's the clutch that is burning but don't know what is making that clutch burn so bad. This is really bathering me. In the summer it happened like 9 times it finally got fixed but i crashed the car (stupid crash but did used the car for 4 months.) then i used it for 2 months and it breaks again. I'm really mad. Please Help Don't know what to do and it's emptying my pocket. My Tranny is the 4l60E(Or what ever is stock for 94) with a Torque converter, Shift kit, Racing Clutch(put it in first breakage), Corvette Servo(Finally fixed the last breakage) and that's about it.
If u have any good help please HELP ME
Old Mar 15, 2003 | 10:24 AM
Greasepunk's Avatar
it's probably the 4L60E, and I'm a little lost as to the 'clutch' on an auto.
Old Mar 15, 2003 | 10:31 AM
TransAm2k4's Avatar
It's not a clutch like in manuals with pedal and all but it's a clucth in the Tranny it's self. It's the way the tranny shift automatically. The tranny press that clutch by it's self.
Old Mar 15, 2003 | 10:34 AM
Greasepunk's Avatar
this may seem dumb, but does it have enought tranny fluid? I've heard of guys gettin a converter and then not putting enought fluid back in it thinking that it is full. just a thought man. I think there was another recent post about a guy burnin up 3rd right after he got a T/C because of lack of fluid.
Old Mar 15, 2003 | 10:57 AM
TransAm2k4's Avatar
The transmission have break about 10 times now if it was that i'm going to kick the mechanics @$$. I hope it would be that simple.
Old Mar 15, 2003 | 10:59 AM
Greasepunk's Avatar
well, just go outside and check the tran fluid level and see if it is low or not. The T/C holds extra fluid and if your mechanic didn't know that (aka a dumbass) then that could be your problem.
Old Mar 15, 2003 | 11:04 AM
pacesetter's Avatar
Re: Automatic Trans. Problems
I dont think its your clutch. If it was, you would have problems in almost every gear. Sounds to me like you have a bad shaft inside the tranny. If it is still under warranty I would take it in and have them look at it. Good way to know that a clutch is going bad is it it over rev's itself in most gear and shifts hard or very slow.
Old Mar 15, 2003 | 11:22 AM
TransAm2k4's Avatar
FLuid is ok but the shaft might be. The tranny was feeling like it was loose when shifting to 3rd until it finally won't get it. what is does is 1-2 ok then 2 runs good and when it shifts into 3rd and it does shift. It's like putting neutral. It just revs doing nothing. i need to shift into 2nd to move somewhere.
Old Mar 15, 2003 | 02:06 PM
68SSElCamino's Avatar
Have you pulled a code? yet another p1870?
Is the shift into reverse delayed?
The next problem will be complete 3-4 clutch failure and, or overheating the converter.
Stator support sleeve issue............
Good luck, hope im wrong.
DirtyDaveW
Dec 1, 2016 05:37 PM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Jan 5, 2015 07:14 PM
