Cross threaded header bolt
Old Mar 14, 2003 | 11:04 PM
94GreenZ28's Avatar
I accidentally cross threaded a header bolt the other night. Should I try chasing the tread or should I leave it? The bolt will tighten its just a little sideways. If I should try cleaning it up what size tap is it?
Old Mar 14, 2003 | 11:43 PM
Threads are 3/8-16. That is a touchy call. If the bolt is fully threaded and tight now (crooked), removing it and chasing the threads out straight might make the hole too large and unusable. If it is in a spot where there would be room to heli-coil it, then you would have a back-up plan.
Old Mar 15, 2003 | 01:02 AM
Austin96Formula's Avatar
Happened to me also. But it was only 2-4 threads in.. I just got a tap and carefully turned it and got it to where the bolt went back in no problem.
Old Mar 15, 2003 | 09:27 AM
Bud M's Avatar
First I'd try to just remove it and put it in right (assuming it's not screwed in real far.) If that won't work, chase it and go to a 1 inch long bolt just to be safe.
Victor Lamb
Aug 26, 2017 02:52 PM
Richardan15
May 30, 2015 08:36 AM
maybe2fast
Mar 16, 2015 09:45 AM
moparman
Feb 11, 2015 08:29 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
