Is the ceramic coating on headers REALLY worth the 200 bucks??
Old Mar 14, 2003 | 01:53 PM
MrZ's Avatar
MrZ
I eventually want to get a set of LTs, but I wanna know if I should save myself the extra money. I know they help with heat in the engine bay, but does it do anything else?
Old Mar 14, 2003 | 01:59 PM
LWillmann's Avatar
I believe that it also helps keep them from rusting. Jet-Hot warantees them when they coat them brand new from rust through.
GREGG 97Z's Avatar
Preventing rust is the other big reason. Some of the LT's like the Hookers are not stainless and will rust without the ceramic coating. I got SLP's which are stainless and I didn't get them coated and they started to rust too. It's just surface rust but it makes them look crappy, I will probably end up pulling them out and getting them jet hot coated eventually.
Old Mar 14, 2003 | 02:06 PM
Advantages of ceramic coatings:
-Keeps exhaust gas temps higher, increasing velocity and scavenging. This nets up to 3% extra HP, according to Jet-Hot.
-Reduces corrosion
-Reduces stress cracking from temp cycling and vibrations.
-Reduces under hood temps.
-Looks good.....
Old Mar 14, 2003 | 02:08 PM
mobleman's Avatar
just an FYI
Ceramic coating does help prevent rust, but if you live in the north and drive in the snow at all you may have problems. My coated MACs didn't last 2 years without major rust issues.
I have to take them off and get them recoated this spring
Old Mar 14, 2003 | 02:25 PM
atljar's Avatar
My hooker ceramic coating only lasted a few months before rusting through.
Old Mar 14, 2003 | 02:31 PM
Rearpl8tsinsite's Avatar
I have heard of some people having problems by not getting the coated ones. One example is plug wires melting causing arching. There are numerous other parts near there that will prematurely fail with excess heat. One of these things goes wrong and you will end up paying over that to fix it even the plug wires. It will be worth it in the end.
Old Mar 14, 2003 | 03:47 PM
Xscream's Avatar
Well there is a simple solution for everyone.
Wrap them
Yes they still rust but they will keep the bay temps down significatly more than coatings will and you don't have to look at ugly headers.
Old Mar 14, 2003 | 04:21 PM
Max 93's Avatar
coated headers will aslo be easier to sell when you do get the LT's.
Old Mar 14, 2003 | 04:28 PM
TheV6Bird's Avatar
Yes, but then you will have to look at ugly header wrap instead
Old Mar 14, 2003 | 04:37 PM
Mir Hussain's Avatar
Arrow
I have Jet2000 from JetHot on my MAC.
Hell you can touch them in 5 min after shutting off the engine
So for no rust! i had it coated almost 2 years ago. I came to north about 4 months ago
So far they looks ok
We will see once summer will come to this Northern world
Old Mar 14, 2003 | 05:21 PM
93Z286Speed's Avatar
coat em.. do it right the first time
ull be kickin yerself in the *** later if u dont
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
WildRidez
Mar 27, 2015 08:22 AM
99TransAmWS6
Feb 12, 2015 07:23 PM
jim88iroc305
Aug 13, 2002 09:24 PM
