anybody have used gears??
Old Mar 14, 2003 | 12:26 PM
irocz8957's Avatar
i was wondering if anybody out there has used gears for a 9bolt i have 277's right now and want like 323 or 342
Old Mar 14, 2003 | 01:11 PM
Black6SpdTA's Avatar
someone over in the for sale section had some 3.42's for 50 bucks but i forget his name..they came out of a 94 would they still fit?
Old Mar 14, 2003 | 03:38 PM
87DJP2001's Avatar
Re: anybody have used gears??
You will need a new carrier if you want to replace your (9-Bolt)gears. And 10-Bolt gears like you have mentioned 3:23 & 3:42
will not work.
People seem to forget or do not know that you CAN NOT mix 9-Bolt and 10-Bolt parts. They are NOT INTERCHANGEABLE!!!!!
Old Mar 14, 2003 | 05:21 PM
IROC350's Avatar
re
i'll buy your 9-bolt from you
Old Mar 14, 2003 | 06:53 PM
Dirt Reynolds's Avatar
You're going to be limited to either a 3.27 gear like my car has, or a 3.70 for the M-5 305 TPI 9-bolts.
9-bolt stuff is pretty scarce and pricier than the 10 bolt parts, although the 9-bolt is a lot stronger of the two.
Dave
Old Mar 14, 2003 | 07:03 PM
zupmanZ28's Avatar
i have a 3.27 ring and pinion with about 70k miles. you'll need a 3 series carrier for them though...
email me if your interested (higotoody@hotmail.com)
Eric
Old Mar 14, 2003 | 07:04 PM
IROC350's Avatar
re
if you're buying them new, be prepared to spend about $300
Old Mar 15, 2003 | 12:23 PM
TheGreatJ's Avatar
The 3.70 ratio was only used in the '85 305/T5 cars, 86-89 got a 3.45 ratio. And as far as new gears go....you can buy a complete used 3.27/3.45 posi disc rear for about the same price easy enough. 3.45 rears are hard to find though.....3.70's are even harder. I have the only factory 3.70 9-bolt rear I've ever seen.
Old Mar 24, 2003 | 05:18 PM
88 427 Camaro's Avatar
I have new 9 bolt gear sets to 4.10 ratios.
I have some used to 3.45 too. I am working on some
used ratios of 3.73 and 4.10 that should be ~ 1/2 the
cost of new gear sets. I hope to have the ring gear spacer
stuff worked out soon too. Just trying to finish the rear support cover first.
All the info is at www.9bolt.com or www.diffsolutions.com
I will be updating the availability and price pages these week.
Miles
Old Mar 24, 2003 | 07:06 PM
TheGreatJ's Avatar
Let us know when you get that support cover ready.....I might be real interested depending on prices.
blkWidow
Apr 21, 2015 01:56 PM
CARiD
Apr 8, 2015 08:08 AM
alex5366
Apr 1, 2015 09:27 AM
ChrisFrez
Mar 22, 2015 09:12 AM
