LT1 Questions
Old Mar 14, 2003 | 12:13 PM
Green G0blin's Avatar
LT1 Questions
well i have a 1996 LT1 formula convert.
i have some questions
are my heads iron? alum?
are they interchangable?
which are better for port and polishing?
Old Mar 14, 2003 | 12:26 PM
Re: LT1 Questions
All F-Body and Corvette LT1 heads are aluminum. Only the Impala/Roadmaster/Fleetwood heads are iron
All LT1 heads are interchangable year-to-year.... e.g. 97 heads will fit on a 93. Iron heads can also be fitted, unless they are from the 265ci "Baby LT1" from the Caprices. You can also interchange LT1 and LT4 heads, as long as you use the matching intake manifold. You can not interchange LT1 heads with earlier "Gen 1" small-block Chevy heads, nor with the later Gen 3 LS1 heads. You could modify the Gen 1 heads to fit, but it involves welding up some water passages and drilling some new ones.
Supposedly the earlier heads are a little thicker, but not sure how much difference it makes.
Old Mar 14, 2003 | 12:54 PM
thank you very much...appreciated.
oldschool
Feb 9, 2016 09:21 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro90RS
Jul 23, 2002 07:57 AM
