valve springs
Old Mar 14, 2003 | 10:51 AM
camaroSSlover's Avatar
valve springs
i have been reading alot about the lt1 trying to get the most info and getting pepared for installing a cam. then i came across guys talking about valve springs maby you guys can clear some of this up for me.
when i find a cam kit like the hot cam or somthing from cmotorsports do i just slap the springs on and set the valve lash or do i have set and test valve height, coil bind ,seat pressure? if so how go i do this? do i need to get some spesialty tools like a barrel mic.?
thanks guys i'm in the dark with doin the cam install myself and i want to be clear about every thing before i order a cam
Old Mar 14, 2003 | 11:10 AM
96z's Avatar
96z
If the spring came with the kit you should be fine. Its when you buy a spring "you think will work" or if your unsure what spring it actually is that you would want to measure everything.
Old Mar 14, 2003 | 02:07 PM
You might want to read this thread for other opinions/info:
http://web.camaross.com/forums/showt...threadid=89952
Old Mar 14, 2003 | 02:29 PM
mongse_1's Avatar
I always test my springs. Seat pressure, coil bind, installed height, etc. I've come to find out that what a company says, isn't always exactly true.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
nikolt1
Feb 27, 2015 09:10 PM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
