Jumped curb!!! messed up steering!
Old Mar 10, 2003 | 04:59 PM
MadMaxz28's Avatar
i jumped a 4" curb pretty hard f'in around like a dumb f%$#!!! anyway i have to hold the wheel at 2:00 to keep car straight.. doesnt rattle or shake that bad untill i hit brakes but it did that before... im putting it on the rack tomarrow.. what do i look for?
Old Mar 10, 2003 | 05:13 PM
scyzoryk's Avatar
I have the same thing,.....
I dont remember the part name but it is a 10" straight 0.5 inch in diameter piece of metal. About $15.99 in Auto zone + 30 minutes of work...
Old Mar 10, 2003 | 06:06 PM
The Sixth's Avatar
I've done that before. I did like a 360 while doing it too.
I just simply had to get all aligned.
Old Mar 10, 2003 | 06:12 PM
Inner, outer or both, tie rod ends would be a good bet.
Old Mar 10, 2003 | 07:58 PM
blkn'silver94's Avatar
whats that thing from autozone your talking about?...this same thing happened to me(so to feel to bad) and have the same problem...what should i ask them for?...thanks Tony
Old Mar 10, 2003 | 09:28 PM
scyzoryk's Avatar
Tie rod end” Depend which wheel hit the curb that tie rod end you will need. It just bent so the best thing is to replace with a new one and then to and do wheel alignment.
Old Mar 10, 2003 | 09:40 PM
bad96firechikin's Avatar
Hopefully you didn't do any damage that requires the vehicle to goto a body shop. I work in a shop and see frame/structural damage all day long.
Old Mar 10, 2003 | 09:51 PM
akafred's Avatar
ah just jump one the other way it allways works on the old winter beaters
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
tdigger9899
Sep 7, 2015 10:56 AM
