MAF malfunction and running lean
Old Mar 10, 2003 | 04:28 PM
aubs's Avatar
hey guys
i got codes 100 (MAF malfunction) and 171, 174 ( R+L banks lean)
I cleaned the MAF sensors w/ electronics cleaner and put fuel injector cleaner and a new fuel filter on the car. Its still throwing the same codes, gonna check my fuel pressure when I can borrow a gauge, any ideas on the MAF? Am I on the right track guessing that my fuel pump might be going? would bad O2 sensors affect this? I checked for exhaust leaks, plugs and wires look ok too. car only has 60k easy miles. thanks for the help
Old Mar 10, 2003 | 07:11 PM
97FormulaWS-6's Avatar
To me it sounds like you've got a shot MAF....
Easiest way to check would be to swap in a known good one...
I just got a jode 100 and my car ran like crap... I unpluged the MAF(PCM went into Speed Density Mode), car ran 100 times better... so I got a new MAF... Solved the problem.
DirtyDaveW
Dec 1, 2016 05:37 PM
grabbem88
Feb 13, 2015 03:09 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
