97z idles fast? HELP
Old Mar 9, 2003 | 01:36 PM
remaxracer45's Avatar
I have a 97 z with a hypertech chip a 52 mm throttle body ported maf throttle body bypass slp loud mouth k and n cold air kit a ait relaocater kit and on occasion my car wants to idle at 2K rev it up it doesn't change, no service engine lite other wise rune good please help.
Shawn
Old Mar 9, 2003 | 07:46 PM
$hawn's Avatar
I'd first check and clean out the idel air control valve.
Old Mar 9, 2003 | 08:00 PM
How can you check this? I did pull it out once and clean it and push the valve in and pulled it out and it did seem to fix it for awhile. Shawn
Old Mar 10, 2003 | 01:25 AM
Ryan 97 Ram Air T/A's Avatar
To test it use an ohmeter to check the resistance across its terminals. With the car off, unplug the connecter. It has 4 terminals all in a row. Check the resistance across the top 2, and then across the bottom 2. They should both be between 40-80 ohms. If not, then that's where you should start.
I had the same problem, but the guy who programmed my ECU fixed it. If possible, take out your chip and see if it goes away.
Good Luck
Old Mar 10, 2003 | 08:17 PM
I have the same problem without the chip. I don't have a ohn meter so i'm going to just buy a iac valve and see.
Old Mar 11, 2003 | 12:15 PM
ttt
Old Mar 11, 2003 | 01:34 PM
Hal Fisher's Avatar
Also make sure the throttle cable is properly connected to the holder. I grounded off the plastic part that connects it to the holder because it was a pain to take on and off. About a year later I started having problems and had to get a new cable.
Hal
Fastbird93
May 22, 2015 08:28 PM
maybe2fast
Apr 23, 2015 08:55 AM
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Mar 1, 2015 01:33 PM
maybe2fast
Feb 5, 2015 05:14 AM
