Problem with wipers, Need your help!
Old Mar 9, 2003 | 10:47 AM
Onetuffride's Avatar
Ok, I'm having trouble with my wipers not going down after I turn them off. The wipers work fine, but when I shut them off they don't go down all the way, they sit up on the windshield. Is this a relay problem? Or is there something else I need to be looking for.
Tuff.
Old Mar 9, 2003 | 12:51 PM
Mtrhds94Z's Avatar
It's the PC board inside the wiper motor assembly...
What I did is get a used wiper motor off the 'for sale' forum here for like 20 bux and its been OK ever since..
I think a new wiper motor assembly is about 200 or so..
Old Mar 9, 2003 | 01:07 PM
Thanks for the help, I wasn't shore. I was hopin' that it would be a relay, not the wiper motor.
Tuff.
Old Mar 9, 2003 | 01:12 PM
cndctrdj's Avatar
i had a problem with my wipers. after trying and trying everything i found out it was the switch on the steering column that was broken, if nothing else works replace that. my wipers would come one and then about 3 min into it they would stop usually in the middle of the window.
Old Mar 16, 2004 | 03:33 PM
1FstFormulaV8's Avatar
Where is the wiper relay? And I'm having problems with mine too. Is it hard to replace the switch? And how do I change it?
Old Mar 16, 2004 | 04:10 PM
naztyz28's Avatar
cap sells them for like 60 bucks i think it was thats list tho and i had the same proub changed the motor all better
Old Mar 17, 2004 | 04:11 PM
Wiper.
The wipers come on automatically when you mist the winshield? Right? So if the switch went out. There'd be no mist would there? Wouldn't that trigger the wipers, and eliminate the switch going out?
Old Mar 17, 2004 | 05:22 PM
TobyZ28's Avatar
GM Sells a wiper cover kit which basically replaces the cover kit components in your existing wiper motor assembly. (the up/down control thinggy).
Problem is if the kit doesnt fix it (which it should) you can't return it because its electronic.
I bought a remanufactured motor.
Old Mar 17, 2004 | 06:16 PM
Mtrhds94Z's Avatar
That's the PC board on the wiper motor I was referring to in above post.. [it controls the 'park' etc..]
Also, there is no 'wiper relay' in these cars..
Red Hawk 94
Mar 18, 2019 04:03 PM
R@mpage
Apr 20, 2015 10:02 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
stopthatman
Feb 9, 2015 09:00 PM
Jlo
Feb 3, 2015 09:41 PM
