How much timing are you guys running and how to retard it?
Old Mar 7, 2003 | 06:57 PM
Highlander's Avatar
Im curious to what setups are you using and what timings are you running with your boosted applications...
The other point is... how to retard???
Is it better to use a BTM or just do a plain curve on the 100kpa vs rpm table to suit it better?
Old Mar 9, 2003 | 08:32 AM
Highlander's Avatar
TTT
Old Mar 9, 2003 | 10:48 AM
Willie's Avatar
My reply is probably N/A to most here because I own a third gen -- not too many boosted TPI's here, but here goes anyways:
305 TPI
9.2 to 1 CR
D1SC -- currently running 14-psig boost @ 6,000 rpm
Custom ATI twin IC's
Carroll water/alchohol injection
AFR 190's, angle milled to produce 56cc chambers
Pump gas (91 octane)
Zero degrees of knock retard through the 1/4-mile.
36 degrees total timing at WOT with NO RETARD -- don't need retard because my IAC's are 85 - 90 degrees max. I don't think fourth gens with their high CR's can run anywhere near this timing nor this kind of boost.
Old Mar 9, 2003 | 11:19 AM
Hal Fisher's Avatar
All matters on how much boost on what octane gas. I get knock at only 4# and 91 octane. I run with the pcm set 2 less and a btm that takes about .7 per pound out. But you really have to mention what your conditions are.
Hal
Old Mar 9, 2003 | 01:01 PM
Highlander's Avatar
9:1 383
9psi vortech s-trim no IC
224/236 cam
I currently reprogramed my car for 35 total advance and I want to retard about 1 per boost with no knock.,, Hope so...
IATs are around 175
Old Mar 9, 2003 | 01:49 PM
Hal Fisher's Avatar
Right now that might work but expect your IAT temps to increase in spring/summer (might see 200+).
Does that 35 include the 2 added internal? Does your table show 33 or 35? What was your octane again?).
Hal
Old Mar 9, 2003 | 02:59 PM
Highlander's Avatar
32.. my pcm add 3
I did a scan today.. running all over.. and I am seeing a lot more retard than normal and my blms are leaner now than yesterday... dont know why since i did no changes to anything...
my IATs are climbing 200F!!!!!!!!!!!!!!!! TOO MUCH!!! and... I am getting to IATs of 160 at idle... come on... what is the matter here??? Ambient temp is around 90-93F here....
Old Mar 9, 2003 | 03:01 PM
Highlander's Avatar
No matter what I do... I have to set the dial to 2º/psi... I had 37 advance and I did 2º on the ****.. now I have about 35 and 34 and I cant get it to 1.5º/psi yet!!!!!
I can tune anybodies car... but when it comes to mine I dont know what is happening.. same thing with computers...
Old Mar 9, 2003 | 03:23 PM
Monty's Avatar
I'm using a FAST SEFI system, here's my spark map I use for 1200hp on 93 octane at 20-25psi of boost. Peak IAT's are around 130F on a 90F, humid day.
Old Mar 9, 2003 | 03:28 PM
Highlander's Avatar
Can someone check out this datamaster file???
http://netdial.caribe.net/~highland/32deg.uni
or
What are your IAT temps???
I see you are running ~25 on what could be 10psi... but what are your IAT temps????
I was hoping to run 25º of advance at 9psi but so far its been a bit difficult...
Old Mar 9, 2003 | 03:38 PM
Highlander's Avatar
130F... diff of 70F!!! A lot...
Maybe that is my major problem.. the thing is that the intake is getting heat soaked.. because as time goes by IATs get higher and higher...
Feffman
Oct 9, 2015 05:42 AM
mikey4play
Mar 15, 2015 11:45 AM
nophix
Nov 30, 2014 10:26 PM
sleeperZ96BT
Aug 16, 2002 02:24 AM
Red97LT1
Aug 7, 2002 05:45 PM
