Where to install water temp. sender for Autometer water temp gauge?
Old Mar 7, 2003 | 10:42 AM
n2oTransAmLT1's Avatar
Exactly that. Where do I install that little sender? Is there somewhere it will just screw right in...or do I have to drill and tap somewhere? Thanks
Old Mar 7, 2003 | 10:48 AM
There is a tapped hole with a plug in the passenger side head, between #6 and #8.... essentially the same hole used for the coolant temp sensor in the driver's side head. But it is sort of blocked by the exhaust, making it hard to add a sensor. I just added a "tee" in the line from the back of the heads:
Coolant Temp Sensor
Old Mar 7, 2003 | 11:52 AM
Thanks Fred...Your always a big help. Later
Old Mar 7, 2003 | 04:54 PM
rmackintosh's Avatar
Fred,
I am building a racing only 94 Lt1 and have heard that the sensor in the drivers side head between #1 and #3 is for the guage sending unit only....NOT THE PCM. Is this true? I would like to use this for my Autometer mechanical sensor.
Thanks,
Randy
Old Mar 7, 2003 | 06:04 PM
Fuels94TA's Avatar
Originally posted by rmackintosh
Fred,
Thanks,
Randy
That is right the sensor on the driver side head is for the gage reading in the dash of the car. There is another sensor front of the water pump which is hook up to the PCM.
Vinny
Old Mar 7, 2003 | 06:16 PM
Thanks Vinny!!
brentbrowning01
Dec 16, 2014 06:35 AM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
