cam
Old Mar 5, 2003 | 05:24 PM
smokindastangs's Avatar
cam
Ok here is the deal, I am seriously thinking about putting a performance camshaft in my 94' z28. The one i am looking at is the 306 Lift: .555''/.555'' RPM Range: 3000-7000. I was wondering if it would be stupid to do this with out replacing the heads. Also, i would like to know how much of a difference i will see w/ alimunium heads vs. ported. Thanks!
Old Mar 5, 2003 | 05:41 PM
twells's Avatar
if you are talking about the cc306 cam, i would seriously consider getting some headwork done before installing this cam. you might also want to think about what you want out of your cam. with a 306 cam, you might have to spin your motor a little higher in the rpm's than most would want to take a stock shortblock. i am not sure what you are talking about between the aluminum heads and the ported heads. you can have both.
thomas
Old Mar 5, 2003 | 05:47 PM
About the heads I was wondering what the gain of the aliminum heads would be. I know that you can port them, but why would i want to port aliminum heads opposed to porting the stock heads.
Old Mar 5, 2003 | 06:31 PM
anaik's Avatar
Stock heads are aluminum.
Old Mar 6, 2003 | 12:18 PM
wow..i am an idiot
Old Mar 6, 2003 | 12:37 PM
stik6shift93's Avatar
Porting them will help out a lot, though there are a few people that have run that cam with the stock heads and have had good results.
rideordie
Nov 5, 2019 04:52 PM
alex5366
Feb 17, 2015 08:12 PM
Queens94z28
Dec 20, 2014 09:11 PM
Queens94z28
Nov 20, 2014 06:03 PM
