Code 84?? What's it mean??
Old Mar 5, 2003 | 09:08 AM
sp528's Avatar
Question Code 84?? What's it mean??
I got my cable from AKMcables yesterday and when I plugged my T/A in today everything looked good except it had "Code 84 3-2 downshift feedback fault (odm)" in the list of trouble codes. What exactly does this code mean, and what should I do to fix it?? Thanks for any help.
Adam
Old Mar 5, 2003 | 09:21 AM
Not sure where you got that code explanation and I assume your car is an M6, because the code is for the skip shift solenoid. Check it's connection or bypass if you have one.
Old Mar 5, 2003 | 09:25 AM
sp528's Avatar
I got the code from FreeScan. Yeah my car is an M6, but I have the skip shift disabled at the PCM so I guess that's where that's coming from?? Never thought of that. Thanks.
Adam
Old Mar 5, 2003 | 10:34 AM
If you "disable" (= disconnect) skip shift on the OBD-I cars, the SES light will not come on but DTC 84 will set in the PCM. You need the resistor across the wires to eliminate the code.
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
