3.4 to LS1 Swap
3.4 to LS1 Swap
okay.... LS1 is from a 97 i think trans am..... hows the fit into a 94 3.4 camaro.....bottom line what am i gonna need to make this work....anything will help...will get more details after....tranny is being swapped too
Re: 3.4 to LS1 Swap
ls1 don't fit into 93-97 cars. The ls1 is a taller engine. THe reason they redesigned camaros in 98 was to fit the ls1's into the car. and like he said, 97 f bodies had lt1s. only corvettes had ls1 in 97.
iv'e heard it may be able to fit, but it just isn't worth it. I would just get a v8. But if you really want to swap engines just get an lt1. it is much cheaper and it will fit easier. Also it has about the same potential as the ls1 if you are planning to mod it.
-Eric H
Heh, the time and money spent on doing an V6 to LT1/LS1 conversion is not worth it IMHO. I've thought about doing the swap on my '96, but after seeing the parts list and all of the crazy stuff that has to be done to the car, I decided to just leave well enough alone. If you do decide to go for the swap, good luck!
Originally posted by CrockRocket94
I guess it could be good for insurance reasons
carguyshu
Jan 22, 2017 11:19 AM
