Flywheel Removal Problems
Old Feb 28, 2003 | 05:58 PM
Teal94Z's Avatar
For the life of me, I cant get the factory flywheel off, those bolts are on there tight! Everything else has gone fairly well, and smooth, until this. Also, the factory wheel has heat marks in it, and very very small hairline cracks, is this normal? The car had the original clutch in it, and the disk and pressure plate were worn pretty bad. Anyways, thanks for the input...
Old Feb 28, 2003 | 06:01 PM
DjArcadian's Avatar
That's normal. Needs resurfacing. Use some of that liquid wrench stuff. Some peopel recommend something called PB Wrench when I asked a while ago.
Old Mar 1, 2003 | 09:05 PM
Fullagar's Avatar
I had the same problem when I did my clutch a couple weeks ago. I ended going out and buying a flywheel turner. (took me awhile to find one too). Pretty neat tool though, hooks on to the flywheel pull it one way and the bolts the other....worked great.
Fullagar
Old Mar 1, 2003 | 09:08 PM
SStupid's Avatar
Impact
1/2 inch impact works everytime to get the bolts out.
Old Mar 1, 2003 | 10:17 PM
Pb Blaster, long breaker bar and a 6 point socket.
DirtyDaveW
Dec 1, 2016 05:37 PM
Ringmaster72
Feb 25, 2015 03:15 PM
97SSdude
Dec 31, 2014 07:43 PM
mattszm6
Dec 14, 2014 07:09 AM
Mikes 1994 z28
Nov 25, 2014 02:00 PM
