car shakes after headers/oil pan gasket.. but its not plugs/wires
Old Feb 28, 2003 | 01:05 PM
mineralwater's Avatar
Well, I did the mac 1 5/8th headers with ypipe and offroad pipe, and I also put in new taylor 8mm wires. I used zipties to tie them together along the block, so it doesn't touch the headers. It *never* has come into contact with the header primaries as far as I know.
I took my car into the shop after that to get my leaky oil pan gasket replaced (I tore it when I did the cam install), and the shop installed it fine. However, when I got the car back, the idle was shaky, and at low rpms, the car just "chugged", and kind of shook. Going at a high gear/low rpm/high load, the car will buck and shake while maintaining speed...
now the symptoms all point to burnt plug wire/loose plug. I checked all the wires today, made sure they "clicked" in on the plug and on the opti... none of the wires were burnt as far as I could tell.
Any ideas? Help or pointers would be appreciated.
Thanks,
Old Feb 28, 2003 | 01:10 PM
HungryT/A's Avatar
It is sure it's missing.
They must have messed up the opti when they replaced the oli pan gasket.
Or, you could have a cracked plug.
Sorry, can't help too much...
Old Feb 28, 2003 | 01:11 PM
does the opti have to come off with the oil pan gasket? I don't think they touched it...
but yeah, the symptoms point to it as a sure miss, I was 99.9% sure it was burnt plug wires until I checked them today..
I guess it coudl be the opti, but it was working fine, and smoothly, until they did the oil pan gasket.
This really blows, because I have to drive home this weekend for family obligations and without the car running.. d'oh.
Old Feb 28, 2003 | 01:23 PM
Sounds like the shop may have messed with your wires and maybe took a couple off and put them back on the wrong cylinders. Guess you better check them all. I would also look for anything else they might have taken off and not put back.
Old Feb 28, 2003 | 01:27 PM
HungryT/A's Avatar
Yeah, that made me think that they messed it up.
PCLZ28
Dec 24, 2015 05:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
USAirman93
Nov 24, 2014 03:37 PM
Elcojoe
Nov 17, 2014 10:27 PM
Bando
Oct 7, 2002 07:36 PM
