Where is the hole in the firewall?
Old Feb 27, 2003 | 01:06 PM
dkeers's Avatar
I have read about a hole that is somewhere behind the PCM but I can't find it. Do I have to remove the entire PCM?
Dustin
Old Feb 27, 2003 | 01:17 PM
Butch 02 SS's Avatar
Yes, remove the PCM and you will see it just below. There is a grommet with wires passing through.
Old Feb 27, 2003 | 04:46 PM
jd13's Avatar
I was able to get to the hole without removing the PCM, all I had to do was take out the two screws/bolts that's holding the PCM in place and have someone hold it to the side. I was able to feed a wire through there from the inside and grab it in the engine compartment area quite easily.
It helps to use a flashlight, it's a little black circle maybe 4" in diameter.
Old Feb 27, 2003 | 04:48 PM
I ran so much wire, I had to take it out. I have 3 gages in the pillar, nitrous switches etc. Made it a lot easier for me.
Old Feb 27, 2003 | 05:03 PM
stik6shift93's Avatar
I removed that garmnet also. I fit a nitrous line threw there, an 8 gauge wire amongst a lot of other wires.
Old Feb 27, 2003 | 07:31 PM
Kwiksilverz28's Avatar
I hope you did not mean grommet. If you did, get one in there. You WILL chafe through the wires eventually, and then you are in trouble when they spark and light up the NO2 line.....
Old Feb 27, 2003 | 10:25 PM
stik6shift98's Avatar
lol good thing i kept my rubber thing there
Old Feb 28, 2003 | 09:08 AM
99_Z_155's Avatar
Yeah, you dont have to take out the PCM. There is plenty of room, especially if you are just running a power cable for your system or whatever.
Old Feb 28, 2003 | 09:13 AM
poniekiller's Avatar
just cut a large slit in the center, or remove the center of the grommet. Leave the outer ring. Once your wires are run, glob some silicone in there to keep any water (and bugs and leaves) from getting inside and to keep the wires from moving back and forth. This will help avoid chaffing.
G-BODYT56
Jan 14, 2022 11:14 PM
drt
Sep 27, 2015 04:39 PM
RobFlag
Aug 29, 2015 11:40 PM
4586
Jul 31, 2015 06:03 PM
gelbza
Jul 12, 2015 08:10 AM
