possible to recharge ac myself or not??
Old Feb 27, 2003 | 10:31 AM
slashz28's Avatar
hi guys my ac leaked out a couple of weeks ago and i was wondering if i could recharge it myself? or it could only be done at a shop? its a 95z. thanks
Old Feb 27, 2003 | 12:20 PM
Josh'95Z28conv's Avatar
You should be able to do it yourself. It should be r134a, and you can by a recharge kit at any parts store.
Old Feb 27, 2003 | 01:28 PM
Blue89Bird's Avatar
if it leaked out, then you obviously need more then just refrigerant. Find out why it leaked, fix that, then you can recharge it.
Old Feb 27, 2003 | 01:38 PM
drop top steve's Avatar
First, find and fix the leak=part charge with ac dye.
After you fix the leak you need to at least evacuate the system, then recharge, a new reciever/drier would be nice.
Old Feb 27, 2003 | 02:27 PM
BackInBlackZ28's Avatar
Recharging is easy, walmart or meijer sells the cheapest recharge kits. They usually come with a sealer or die to help find the origina leak as well. Have fun and good luck!
Old Feb 27, 2003 | 03:40 PM
nateh's Avatar
Drop Top Steve is right. You need to evacuate the system before you fill it up. Pull a good vacuum on it to eliminate moisture and contaminated air.
Old Feb 27, 2003 | 03:52 PM
ToocoolZ28's Avatar
Maybe the CORRECT way is to E-vac the system but I have recharged many cars without doing so and never had any problems. My Cavalier has a small leak, I recharge it every spring but it lasts all season. No problems and cools extremly well.
Ron
Old Feb 27, 2003 | 04:18 PM
JETMAN95Z28's Avatar
I'm in the commercial HVAC/Refrig. business and if you have 100% lost the refrigerant charge you really should evacuate the systems and change out the drier. If it is just low and not cooling as well as it used to (some gas is still in the system) you are OK with a top off charge. If it is completely empty, air and moisture has probably gotten into the system and it won't get as cool as it should due to mixed gases and the discharge pressures can be too high (non-condensables) and greatly shorten the life of your compressor.
Old Feb 27, 2003 | 05:13 PM
mc63's Avatar
I could not have said it better JETMAN95Z28
Right On!!!
Old Feb 28, 2003 | 11:55 AM
slashz28's Avatar
sorry i didnt check this post till now thank you very much guys i know where it leaked from, cause i broke the hose i dont really care, cause i use my ac maybe once a year at most, but i wanna fix it anyway. im gonna replace the tube i broke, vaccuum, then refill like you guys said. i wont bother replacing the drier or whatever yet, no point really. thanks again, ciao.
malikot02SS
Aug 15, 2015 01:11 PM
pimpinphil
May 30, 2015 04:20 PM
95Zdroptop
Aug 17, 2003 02:05 PM
Naegash
Aug 14, 2003 04:09 PM
luis nunez
Aug 2, 2003 01:24 AM
