can a bad alternator cause tranny problems?
Old Feb 25, 2003 | 06:57 PM
ImpalaFasst's Avatar
I had an electrical proble for about a month (flashing gauges, jumping amps, flickering lights). I checked every ground, loose wires ect.. ended up being the alternator-over charging. Replaced that. that night driving home the tranny (4l60e) won't shift from 2nd gear. it slips into 3rd but doesnt fully go in. i have no overdrive too. can a bad alternator short out the 2-3 Solenoid? i dont think its the tranny cause i havent raced with this tranny yet and it only has 4k miles on it. 1-2 shift still chirps the tires. any help wouldbe great.
impalafasst
1994 impala ss
Old Feb 25, 2003 | 08:03 PM
CJ Black LS1 Z28 M6's Avatar
Yes,
I was told the same thing and had the same problem. The tranny shop said that overload caused my shift solonoids to fry. I never thought such a problem would exist. I did have the solonoids and alternator replaced and the car has run good but In a few months I'm going to a 6-speed. Good Luck bro
Old Feb 25, 2003 | 08:48 PM
Hey thanks. i will check that as soon as i can get the car on a lift. I'll tell you if that was the problem.
impala fasst
1994 impala ss
Old Feb 25, 2003 | 09:29 PM
Both the 1-2 and 2-3 solenoids, should have 20-40 ohms of resistance across their coils. You could look at this through the pins on the transmission electrical connector.
Noer
Feb 28, 2015 11:29 AM
mattszm6
Dec 14, 2014 07:09 AM
Snoman73
Nov 17, 2014 07:22 PM
Zomie
Sep 2, 2002 09:04 PM
slothgrant
Aug 22, 2002 03:01 PM
