aftermarket fuel pump
Old Feb 23, 2003 | 10:10 AM
blockhead's Avatar
What aftermarket fuel pumps are direct replacements and will a 255lph affect anything on a mostly stock car?
Old Feb 23, 2003 | 10:12 AM
Greasepunk's Avatar
i recently asked the same question, and as far as PSI and LPH and all that they said it wouldn't hurt anything or change anything really. There are a few products out there, check out Jegs, Summit, all the popular sites...
Old Feb 24, 2003 | 08:28 AM
IDOXLR8's Avatar
IF you are looking for a stock replacement and do not plan on modding your car in the future than you can get away with a Walbro 190 lph.
Old Feb 24, 2003 | 09:19 AM
atlasengr's Avatar
Arrow
I purchased a Granatelli Motorsports fuel pump a while back from Summit Racing and installed it on my 1990 IROC-Z. I upgraded to a new and better--255lph-- due to the addition of the nitous system. The only difference I saw, was about 4-5 psi increase from the stock one. I checked my fuel pressure before I installed it and adjusted it after the installation was complete. This would be a good thing to do before installation. I use 44 psi. I plan to put the same fuel pump on both my 94 and 95 Z28's when the upgrades start going as extreme as my ROC's.
Old Feb 24, 2003 | 03:55 PM
blockhead's Avatar
My fuel pump is going and I will have to replace it at some point. My car does not have any major mods yet, just a few bolt ons. In the future I may do stuff that needs a better fuel punp and I don't want to do it twice. Aftermarket fuel pumps are also cheaper than stock I believe.
Old Feb 24, 2003 | 08:14 PM
LPE Z convt's Avatar
I just purchased a racetronix plug and play kit for 235.00 to the door it is a 255lph pump and all the stuff you need to do the switch no wire splicing all plug in fittings it is a nice set up.
cmyname1
Feb 19, 2015 08:38 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
