good cam?
Old Feb 22, 2003 | 11:04 PM
My84Z's Avatar
good cam?
what do you guys think of this cam and what the hp numbers would be? thanx in advance John
intake 559 lift 267 duration 214 duration@.50
exhaust 566 lift 275 duration 222 @.50
lsa 115
centerline 111
It is a slp cam.
Old Feb 22, 2003 | 11:16 PM
Shempy's Avatar
Nothing wrong with the SLP cam, but it is really tame. However, they've got a new one out, with much higher hp numbers that I haven't seen advertised yet.
You have to ask yourself what you want out of the cam.
High horsepower?
High reliability?
Low RPM Torque?
High RPM HP?
Nitrous or forced induction friendly?
Sleeper or lumpy sound?
Want it to work with stock tuning?
Ever plan to do heads?
Old Feb 22, 2003 | 11:42 PM
My84Z's Avatar
i undestand that i am just wondering what poeple thought about this cam and what it would better suit as far as nitrous..... just wanted to know what poeple would think about this one.
Old Feb 23, 2003 | 01:17 AM
sleeperZragtop's Avatar
Very tame is right....if you want to keep a nice lobe and pass emissions I suggest an LS6 cam...they produce good power but give you a stock feel...good luck
Old Feb 23, 2003 | 01:54 PM
Shempy's Avatar
I'd take the SLP cam over the LS6 cam. Both will idle very smooth, but I think the SLP cam would have a slight performance edge based on the specs. If you're concerned about nitrous, I'm admittedly no expert, but I suspect with the better exhaust lift and duration numbers over the intake numbers, that the SLP cam would be fairly nitrous friendly. Certainly no less friendly than the stock cam.
If emissions are a concern, you can go even bigger, as long as you have the car tuned. Just stay with a cam with a 114 LSA or higher. With good tuning, it is possible to get a cam with up to 224 duration to pass most emissions.
Old Feb 23, 2003 | 09:05 PM
stik6shift93's Avatar
Its a tame cam indeed but still a step up from an ls6. If you're looking to stay emissions legal and keep your lowend that cam would be a good choice.
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
