New Oil pan gasket?
Old Feb 22, 2003 | 12:40 AM
97 RedSS's Avatar
New Oil pan gasket?
Should I buy a new oil pan gasket when I install my Canton oil pan here in a few weeks? Didnt know if it would be necessary or not..
Cody
Old Feb 22, 2003 | 01:01 AM
Super Slow '97's Avatar
go ahead and replace it while you are there that way you know that you do not have to worry about it. They are only $30 so why not.
Old Feb 22, 2003 | 01:52 PM
DaveW 396ci's Avatar
Make sure you completely clean the block gasket surface. The stock gasket is "glued" to the timing cover and the rear main seal adaptor channel. Make sure you get all that crap off. You may want to also run a thin bead of Ultra Black RTV in the same area. Don't over tighten the bolts when reinstalling the canton pan as that will ruin your oil pan gasket.
DaveW
HectorM52
Jul 30, 2017 11:46 AM
PCLZ28
Dec 24, 2015 05:19 PM
willismoons
May 27, 2015 04:03 PM
SergheiS
Apr 26, 2015 08:15 PM
Queens94z28
Dec 20, 2014 09:11 PM
