LT1 vs LS1 drive shaft
Old Feb 20, 2003 | 10:49 PM
dansmysticta's Avatar
Post LT1 vs LS1 drive shaft
Just curious what the difference between the two may be. If there is a performance difference. Thanks
Old Feb 20, 2003 | 10:54 PM
Buttercup's Avatar
Most LT1's came with steel shafts and most LS1's came with aluminum shafts. The lighter aluminum shafts get just a few more horse to the wheels and are less prone to vibration problems, but are also more prone to breakage at the strip.
If you don't have a vibration problem I probably wouldn't put any extra effort into picking up an LS1 shaft and if you drag race with slicks I would invest in a stronger shaft or stick with the steel.
Old Feb 20, 2003 | 10:58 PM
ZDriver96's Avatar
Get a 1le if your gonna get an aluminum drive shaft. Stronger than the LS1, higher critical speed which means less vibrations at lower speeds.
Old Feb 20, 2003 | 10:59 PM
EEz28's Avatar
and where does a carbon fiber one fit in all this.....whats the deal with that type?
rideordie
Nov 5, 2019 04:52 PM
Cam's maro
Dec 28, 2014 09:30 AM
squarehead
Nov 21, 2014 08:02 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
red
Jul 21, 2002 09:43 AM
