moody LT1....any ideas?
Old Feb 20, 2003 | 02:39 PM
95z guy's Avatar
Hey guys,
ok, here's the skinny. i had a bucking prob for over a month now. i replaced the plugs and taped up the intake elbow and the situation improved some. however, whats going on now is that SOMETIMES when i get on the gas it will start to buck quickly throughout the rpm band. if i let off the gas for a sec and then get back on it, it stops completely and runs like a champ. what's the deal with this car ? i don't think any parts are dead, because it would probably do it every time, but i do think something is dying. Please help me, i'm low on funds and just got laid off. thanks to all
Old Feb 20, 2003 | 02:54 PM
atlasengr's Avatar
Question Things to check..
Have you tried checking your spark plug wires??? They could be touching your exh. manifolds or may be ripped a bit here and there. Also, it could be your opti-spark going bad. I sure hope not 'cause it can get expensive. Sorry for the situation. Hope this helps you.
Old Feb 20, 2003 | 05:09 PM
SnkEatr's Avatar
Check the fuel filter, lurching, and hesitation in WOT, then when you let off it comes back normal sounds like its starving for fuel. Its cheap and easy to do less than $10.00 for a filter.
Old Feb 20, 2003 | 05:52 PM
95z guy's Avatar
thanks for the ideas. if anyone has some other opinons feel free to let me know. i am appreciating all the help.
Old Feb 20, 2003 | 10:51 PM
cals400ex's Avatar
i have been told that the o2's and egr could cause a slight bucking/surging. this should only be at low rpm's though, at least if the egr is bad. is your intake elbow ripped? this could be a problem if it is. someone actually mentioned that they replaced the knock module with an lt4 knock module and the surging went away. let us know if you find your problem
Old Feb 21, 2003 | 03:15 PM
95z guy's Avatar
i giving the fuel filter idea a run tomorrow. i had changed it last september, but you never know. i'll make sure to fill you guys in on the results. thanks again
Old Feb 23, 2003 | 06:09 PM
95z guy's Avatar
the fuel filter didn't do the trick. I guess i try the egr next. Am I wasting my time? help is good.
Old Feb 23, 2003 | 06:15 PM
joeSS97's Avatar
It sounds to me like the problem is your plug wires.Test them with an ohm meter.If they are old I would replace them.
Girrrrl
Aug 20, 2015 09:26 AM
Girrrrl
Aug 20, 2015 06:17 AM
TGGodfrey
Aug 18, 2015 06:08 PM
Devinfoote87
Parts Wanted
Aug 6, 2015 05:05 PM
asilomar244
Jul 12, 2015 05:53 AM
