Powerless windows on my door
Old Feb 19, 2003 | 01:41 PM
thelategreatz28's Avatar
Hey guys, I dont think this is the right place to post this but it is the closest to the topic so here goes:
I unscrewed everything on my door and it is readey to take off, but the damn window roller thingy is in the way, how do I take this off so I can take off the door panel!?
Old Feb 19, 2003 | 01:47 PM
teke184's Avatar
typically they just pull off, i've read that it is recommended to slide something behind the center part, and just slowly work it around till the handle comes off of it's shaft....it's also worth a look to see if there is some type of pin or locking screw on the side...
Old Feb 19, 2003 | 02:19 PM
94-3.4's Avatar
There is a metal c clip looking thing on the backside of it. You can get a tool at checkers for a couple bucks to remove it and it will help to put it back on too. Or you can get talented and use a flat blade screwdriver.
Old Feb 19, 2003 | 05:25 PM
Like this.
Old Feb 21, 2003 | 09:17 PM
robob's Avatar
When you are ready to replace the window crank, just install the clip in it's properly seated position on the crank, line up the position of the crank (proper clocking, 1, 2, 3 o'clock etc.) on the splined shaft and hit it with the bottom of your fist. It will seat in place without the use of any tool.
Aaront810
Aug 29, 2020 09:34 PM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
z28cam1993
Sep 9, 2015 04:08 AM
gelbza
Jul 12, 2015 08:10 AM
