Anyone running a mechanical Autometer water temp guage in a F body?
Old Feb 19, 2003 | 01:04 AM
FASTFATBOY's Avatar
Anyone running a mechanical Autometer water temp gauge in a f body? If so where did you run the "bulb" through the firewall? And how did you get the bulb mounted in the head? Would it be easier to an electric water temp? I wanted the gauges to match so I bought both mechanical gauges and realized it was gonna be a PITA to get that bulb ran up front.
David
Old Oct 26, 2006 | 12:33 PM
InEviTableSS's Avatar
ttt I need info on this as well.. the fitting that comes with the gauge is too big to go into the head. the fitting that they give you for the electric one fits great but the one for the mechanical one doesnt fit!
Here are some pics of the autometer mech water temp gauge. The blue fitting is the only one that will fit into the LT1 head. But you can't just install the gauge with the blue fitting cause it will leak. AUtometer gives you the red fitting that you see which has to be installed as well. But unfortunately that fitting is too big.
Old Oct 26, 2006 | 08:20 PM
93black-ta's Avatar
i had the same gauge and problem, i took a plug out of one of my heads and went to home depot and matched it with one of their brass fittings, then bought the necessary fitting to install the gauge. there is a fitting that adapts the the red fitting to the head.
i ordered an auto meter one from summit but is was the wrong one, they have so many i couldn't tell what size i needed.
Old Oct 26, 2006 | 08:34 PM
CamaroRacing12's Avatar
anyone have a tutorial on installing...... Autometer mechanical engine temp and oil pressure gauges? i would love to do em myself but i have no idea.....
thx in advance guys
Old Oct 26, 2006 | 10:48 PM
awesome, yea I just found the fitting that goes from the RED fitting and converts it back down to the blue sized fitting. Got it at a place where they sell hose products etc.
Old Oct 27, 2006 | 06:59 AM
thx in advance guys
Run the line and screw it in? Is there something more?
Old Oct 28, 2006 | 01:12 PM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 10:44 PM
