steering columns interchange
Old Feb 18, 2003 | 11:19 PM
93TAWicked1's Avatar
Could I put a 97 z28 Steering column in my TA as long as I had the key to go with it???? Just the column use my steering wheel and airbag??
Old Feb 18, 2003 | 11:35 PM
Blue89Bird's Avatar
im sure it would bolt up and work, but you'd have to do something with the vats and probably loose your controls for the stereo as well.
Old Feb 18, 2003 | 11:39 PM
Too bad the Vats is what I was worried about I have an aftermarket stereo already.
Thanks!
Old Feb 18, 2003 | 11:49 PM
Blue89Bird's Avatar
i guess you could swap your tumbler assembly into the new column, maybe shoebox knows something?
Old Feb 19, 2003 | 12:23 AM
I don't know much , but you would have to use the key cylinder from the original column or defeat the key pellet with a resistor under the dash. The PassKey module under the dash, will be looking for the value from the original key.
IndyZman
Oct 22, 2015 02:17 PM
jackpawt883
Sep 10, 2015 08:53 PM
rideordie
Sep 7, 2015 08:22 AM
War Engine
Aug 28, 2015 06:04 AM
Schul365
Aug 25, 2015 05:47 PM
