LT4 starter users..
Old Feb 18, 2003 | 12:01 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
LT4 starter users..
I noticed the mounting area is thinner.. did you use shorter bolts, or do you need to space it off the block? thanks
Old Feb 18, 2003 | 12:28 AM
Dr.Mudge's Avatar
The LT4 starter is the same as the LT1 Vette starter, yes? I'm using regular old bolts, seems to be workin fine still. I think I replaced it almost 2 years ago.
Old Feb 18, 2003 | 12:38 AM
allmotorta's Avatar
Yep
Old Feb 18, 2003 | 02:05 PM
turns out that there is a gen 1 and gen 2 starter, each require diff bolts.
Old Feb 18, 2003 | 02:24 PM
95 Z/28 LT1's Avatar
Super Moderator
When I installed mine, I used the same bolts.
I used the part #for the '96 LT4 Vette when I ordered it.
Part #10455709
Old Feb 18, 2003 | 04:04 PM
Dr.Mudge's Avatar
I'm pretty sure I had enough thread to be confident in leaving it alone, I've had it off a couple times since then, but it stays on without problems and starts up great. Starts up faster than stock slightly, also sounds a bit different, but works fine so far, stock bolts.
I replaced mine because the housing on the stocker decided to disintegrate.
Formula Steve
Sep 19, 2023 08:31 AM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
