XE grinds and the need for new lifters.
Old Feb 14, 2003 | 12:01 PM
CARGASM's Avatar
Taking into consideration the steep characteristics of the XE grinds, (I am installing the 224/230) is the need for new lifters a good idea?
If this cam is going to cause the need for new lifters in a short time, I night as well do it now.
If it matters, I have '94 w/50k miles.
Tia, Adam M.
Old Feb 14, 2003 | 12:14 PM
rickyzZ28's Avatar
I would put new lifters in just as an insurance option. You have it all tore apart and I would not want to risk damaging my new cam by running old lifters. I would look into Comp R lifters.
Old Feb 14, 2003 | 01:19 PM
cef97ws6's Avatar
Cargasm I have an XE cam and I spoke with Comp about lifters and they assured me the stockers would be fine. The only reason to change them would be for an existing problem. Just check the roller on the old ones for smooth operation and any other visual damage. If you find nothing run-em don't waste your money.
Old Feb 14, 2003 | 01:21 PM
All_Z_Way's Avatar
This is the very question I was about to post about.
I have the XE230/236 and I have been told both.
What options do we have for lifters?
Old Feb 14, 2003 | 02:04 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
i have the Xe 236/242 with strong valve springs
i'm more worried about my seat breaking than my lifters colapsing
Old Feb 14, 2003 | 02:10 PM
Mikey97Z's Avatar
You're worried about breaking the valve seats? How does that happen? I just installed XE230/236. Do these steeper ramps require tighter valve lash? Please explain to me!
Old Feb 14, 2003 | 02:15 PM
treyZ28's Avatar
it was joke
i meant my seat i sit on
as in i'm not worried at all
Old Feb 14, 2003 | 02:19 PM
rskrause's Avatar
Moderator
I reused my OEM lifter with a 214/224 XE grind with very steep (31xx series) lobes with no problems. Then again, 50K is a fair number of miles. You might consider replacing them as "insurance" while it's apart. Depends on your budget and risk tolerance. What you definitely should replace are the stock pushrods with HD pieces. The stockers will not like the higher loads from the springs you will need to use as well as higher rpm.
Rich Krause
Old Feb 14, 2003 | 03:57 PM
OldSStroker's Avatar
Listen to Rich Krause.
I strongly agree with using the best pushrods you can buy. Check for the correct length on your engine with and adjustable pushrod (available from Comp).
Old Feb 14, 2003 | 09:29 PM
CARGASM's Avatar
****I need to type fast, my girlfriend is in the shower...I am supposed to be acting romantic.*****
I already have a new set of cmotorsports chromoly pushrods. I am a big fan of going overboard in terms of security so I will go ahead and get a new set of lifters. The extra couple hundred bucks is worth not breaking at 6000 rpms
With that said, what is everybody using for lifters since the comp R's seem to be in the land of discontinued.
Thanks, Adam M.
Old Feb 14, 2003 | 09:45 PM
drop top steve's Avatar
I've had good luck with Crane roller lifters, used with a 224/230 xe 3100 grind, Crower 68390-3 springs and cm pushrods.
Old Feb 15, 2003 | 09:02 AM
Thanks, Adam M.
LOL! So why weren't you also in the .......?
Old Feb 15, 2003 | 03:26 PM
CARGASM's Avatar
Beacause I am a dirty bastard who doesn't care if I go out in public still smelling like sex.
So, Crane roller lifters...any other thoughts?
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
