confirm for me how trap speed calculated
Old Feb 10, 2003 | 10:47 AM
got_hp?'s Avatar
originally i had thought that trap speed was just the exact mph you passed throught the finish line
then i heard that trap speed is calculated by how much you accelerate from the 1000ft mark to the finish.......and its not exactly the mph you were going.
someone explain it for me.
Old Feb 10, 2003 | 10:56 AM
Gripenfelter's Avatar
Its an average of the last 100ft whereas a GTECH gives you your instantaneous mph at the 1/4 mile mark.
Old Feb 10, 2003 | 02:54 PM
sseeya's Avatar
Speed is measured in a 66-foot "speed trap" that ends at the finish line.
Old Feb 10, 2003 | 03:20 PM
DougsfastZ's Avatar
The last 66 feet is in the speed trap. Needless to say, you don't want to be in the middle of a shift on the long end
Doug D
Old Feb 10, 2003 | 05:26 PM
got_hp?'s Avatar
ok, but what im wanting to know is
is the speed just an exact speed (like a single instant)
or is it an average of the speed you were accelerating throughout that whole 66 feet?
Old Feb 10, 2003 | 05:34 PM
97bowtie's Avatar
The trap averages your speeds as you break the first beam with the speed you are traveling as you break the second beam, 66 feet later. So it averages 2 speeds.
Old Feb 10, 2003 | 05:41 PM
got_hp?'s Avatar
thanks, thats exactly what i wanted to know.
Old Feb 10, 2003 | 05:42 PM
anaik's Avatar
The speed trap starts 33ft before the finish line and ends 33 ft after the finish line.
edit; I did a search on Google and I'm wrong. Again I let logic cloud my thinking.
Old Feb 10, 2003 | 06:49 PM
sseeya's Avatar
This is a direct quote from the NHRA website, in the section entitled "The basics of drag racing:"
Speed is measured in a 66-foot "speed trap" that ends at the finish line. Each lane is timed independently.
There is no way for it to know what speed you were traveling at the first light, because there is no other point of reference.
The speed trap needs two points of reference to calculate speed. It measures the amount of time it takes your car to travel from point A (the light at 66 ft.) to point B(the finish line) Then it calculates the speed needed to travel that distance (66ft.) in that amount of time.
Old Feb 10, 2003 | 06:58 PM
sseeya's Avatar
Sorry Anaik, your edit posted while I was typing my reply.
Old Feb 10, 2003 | 07:18 PM
anaik's Avatar
I wonder if it's ever been the way I described, like back in the '60's? Back when I was a youngin.
Old Feb 10, 2003 | 08:08 PM
OldSStroker's Avatar
Good memory.
I believe it was 66 ft before and after the finish line, not 33.
I suspect they stopped timing after the finish line because fast cars already have the laundry coming out as they cross the line.
Actually, there are two very powerful telescopes mounted in the stands; they read your speedo as you cross the line.
Old Feb 10, 2003 | 09:08 PM
anaik's Avatar
Originally posted by OldSStroker
Good memory.
All these years I've been keeping my foot in it after the finish line so there wasn't a chance of me loosing a .01 or so. Oh well.
Old Feb 10, 2003 | 11:46 PM
nitrojunky's Avatar
funny thing is, they chose 1/80 mi to make the math easy. As said above, it's the average velocity, i.e. (change in displacement)/(change in time). In this case, averavge velocity (mph) = 45/t where t is in seconds and measured from the time you trip the first light to the time when you trip the second one. sooo if it takes you .5 sec from the time you trip the first light 'till you trip the second one, your trap 'speed' is 90 mph.
Old Feb 11, 2003 | 12:16 PM
And to add a little more info... for just about every class of vehicle, the difference between the "actual speed at the finsih line", and the NHRA "average over the last 66-feet" is not very large. For cars running 100mph, and pulling 0.20 G's (typical of many LT1's), the difference is only about 1 mph.
OldSStroker is right... it used to be measured before and after the actual finish line, and it was changed because the big dog top fuelers and funny cars were delaying braking and chutes to pick up that extra couple mph. As you probably noticed from the past weekend NHRA Pomona on TV, the top fuel dragsters are having difficulty stopping before the sand traps with loss of chute or brakes.......
ZZed
Sep 10, 2002 04:13 PM
jp2002ls1
Aug 30, 2002 08:18 PM
z28kid93
Aug 22, 2002 04:40 PM
Notford95
Aug 20, 2002 01:46 AM
96z
Aug 2, 2002 09:00 PM
