Pacific Alaska, California, Hawaii, Oregon and Washington
to lower my car is it good to?
Old Feb 9, 2003 | 05:48 PM
kal2k's Avatar
if i just take the stock springs cut and coil them??
or better to get a full suspension set up??
i know everyone is going to say get a full suspension set up but just asking if there is anyone who has set this up and if its bad or hard on the car in any way thanks
kal
Old Feb 9, 2003 | 06:05 PM
Tw!tchb!tch's Avatar
I wouldnt cut them , go with Springs or fully adj coil overs . With shorter travel you will want to have a stiffer rate . You Will need an Adj Panhard rod to center your rear again and Control arm relocation brackets to keep proper squat out back and maintain traction . I would also recomend new shocks with or without lowering as the stock ones just plain suck .
Dave
Old Feb 9, 2003 | 06:14 PM
silicuda's Avatar
Lowering your car will give you added handling, and your car's rollover possibility will be reduced drastically as the center of gravity will be closer to the ground.
Whatever you do, do not cut your stock springs. Go with the full kit of aftermarket lowering springs. Eibach lowering kits are the best. You might also have to get adjustable shocks (Koni's are great adjustables and these will cost 1100 dollars for a set of 4).
Hope the info helps,
-Attila
Old Feb 9, 2003 | 07:03 PM
Draco's Avatar
-Attila
Whoa there Nelly. for maximum drop, the sportline kit is good however the spring rates are far too low for decent handling. The pro-kit is actually better for handling then the sportlines when matched with proper shocks. As far as handling goes the pro-kit ain't bad, but I wouldn't call them the best until we know what his suspension goals and reasons are.
There are other kits out there for those wanting even better performance. even with 600+ lb/inch springs on the front the ride isn't that bad... and there are a couple of coil sets out there with spring rates in that ballpark.
The first thing you need to ask yourself is what you want to do with your car (autocros, road racing, drag racing, pure street, show, or some combination).
The second thing is to decide how much to spend. A fully adjustable full coil over setup with matched swaybars, panhard rod, control arms, and bushings will offer the most potential but at the highest cost.
Old Feb 9, 2003 | 07:12 PM
kal2k's Avatar
i want to go super low so wuts the lowest i can go with a kit. I wiont cut and coil the stockers does not seem to be flying high with alot of people
Old Feb 9, 2003 | 07:29 PM
Draco's Avatar
If you just want to ride low without enhancing handling you can cut the stockers (Not sure if I would want to cut 2" off) or go with the eibach sportline kit which is a 2"+ drop. If you do go with a big drop I would recommend new shocks as the stock deCarbons may not offer enough dampening to prevent bottoming out.
Maybe Payam will sell you his Sportline setup.
Old Feb 9, 2003 | 07:43 PM
kal2k's Avatar
wuts payams user name so i can pm him?
Old Feb 9, 2003 | 07:50 PM
sleeperZragtop's Avatar
Payam is sideway_into_3rd....like I told you today..do not cut the springs...and go with a pro-kit or BMR springs...they provide a good drop without sacrificing future mods..like longtubes..you told me you want longtubes so saying that be wise on what kit you go with...I'll like into some prices for you from SLP, BMR and prokit...those are the three best choices for peformance wise...I'll also check on a lid and other stuff you...but don't impluse buy..I can get your very good prices...
Mike
Old Feb 9, 2003 | 08:04 PM
mr_muff's Avatar
Yea Kelly, listen to Mike he is a good guy
If you want low and cheap get the suspension techniques like I have, very stiff ride though. You will feel everything in the road, but I am still waiting to bottom out or rub my tires for the first time when driving. I do how ever rub some speedbumps.
edit: We should get a gp on some shocks in a few months when I have some money to waste
Old Feb 9, 2003 | 08:05 PM
...ok...brand new pro-kit for 210.00 usd...you'll need to get some lower control arms with relocation brackets..
-LCA - 115.00 usd
-Brackets (bolt on) - 120.00
...since you have a t-tops you'll want to get some sub frame connectors - 160.00
...a lid and filter (SLP) - 180.00
.....all prices are in usd and shipped
kal2k's Avatar
alright mike lets do this then lets get a drop kit quick then , i wanna lower it like right to the ground slammed. Thanks
Old Feb 9, 2003 | 08:09 PM
...Thanks Blair ...I can get you GP prices on Bilstein shocks anytime...
Old Feb 9, 2003 | 11:35 PM
Ill sell you my sportlines pics in sig . Its the ws6 . Springs have 3000 km on them and if your seriously interested you can ***RIDE*** in it and feel them
Old Feb 10, 2003 | 12:02 AM
kal2k's Avatar
how much u want for them?
Old Feb 10, 2003 | 01:54 AM
ls1_bc's Avatar
Hi kal2k
For what it's worth I've been told that as a rough rule of thumb for every inch the spring is shorter than stock it should be at least 20% stiffer.So for a spring 2" shorter should be aprox 40% stiffer. So the guys are correct cutting coils is just not a good idea.
Just my $0.02 worth.
PS. If you want to set your car up to handle as good as it looks go over to LS1.com and read some of the posts in the Autocross forum.
