79 T10 clutch
Old Feb 8, 2003 | 10:43 PM
browncamaro's Avatar
Question 79 T10 clutch
I have a 79 camaro with a T-10 4 speed and it's gone through two clutchs just in this year. The 350 that's in it should be making close to 400hp. Whats a good clutch that won't eat my wallet alive?
Old Feb 9, 2003 | 02:56 PM
97z28/m6's Avatar
i would look into a centerforce dual-friction,i heard they're pretty good.
Old Feb 9, 2003 | 08:05 PM
1981zzz's Avatar
I agree with 97z28/m6 thy are as good as thy get
Old Feb 10, 2003 | 01:00 AM
CoryM's Avatar
I was told by a guy who used to run BB 2nd gens really hard that you can use a 12" clutch if you get a bellhousing,flywheel,starter from a 70s truck. Apparantly it will fit in a stock camaro too. I havent verified this yet, I will compare the bellhousings tommorow and see. If so you can buy some pretty stout 12" clutches. I will let you know.
CoryM
Old Feb 13, 2003 | 11:54 AM
CoryM's Avatar
Finally I remebered where I posted this . Could not remember where it was. Anyhow, I compared the clutch stuff and if looks like it should work. There area few different patterns for the transmission ears on the trucks so you have to get the correct one. I *think* the saginaw and tremec 3 speeds are the correct one but I am not 100% sure. I have a Sm465 and a Np435 bellhousing here and neither matched the ST10. Have a unknown 12" truck bellhousing here and it did match the ST10.
I am going to ask a friend what hes got for a clutch. Hes running a M22 in his truck so maybe he will know for sure. You will be hard pressed to bust a good 12" clutch with a 400hp 350ci.
I ended up going for a 11" centreforce dual friction.... hope it holds up.
CoryM
Ericksd
Jan 20, 2016 06:07 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
