Guys using a cat on there Hooker LT's have some ?'s
Old Feb 8, 2003 | 08:34 PM
97WRAITH's Avatar
anyone using just one cat and what kind? after my mufflex y-pipe not much room to put a cat; it will be very close to driveshaft.Input appriecated.
Rob.
Old Feb 8, 2003 | 10:07 PM
atljar's Avatar
I am using two of the larger stock 94 cats on mine. I had a custom Y made. I would advise against them. Mine are comming off shortly, only put them on to pass emissions, which i did.
Alse, wiht them on the car just dumps fuel into the engine. MY 02s were reading over 1.000. At WOT, i am taking out 20% fuel from my stock program, yuck.
Old Feb 9, 2003 | 08:25 PM
97WRAITH's Avatar
should I tell Bryan @ PCMforless Iam going to use a cat before I have my pcm tuned?
Old Feb 9, 2003 | 09:25 PM
atljar's Avatar
YES!!!! Tell bryan about the cats
If you want, you can use my set up as base.
My custom program is following
Tell him dual cat,
i have 2 cats
at WOT,
at Wide open throttle, 100% gas
i took out 20% from stock tables
I took out 20% of my fuel from my stock program
from 2800-6k.
took out the 20% in the rpm range
o2s are pretty constant,
o2 sensors give a rough idea of A/F
but split at 890ish, and 950ish after tune.
These are what my 02s were reading, after the tune, on both banks, (left and right side of the car) Still a little on the rich side, but good for me for now.
BLMs are stock settings.
this gives an idea of your fuel table when you are just cruising around. Computer aims for 128 (i think)
That shoud give him a good baseline, but he might have his own formulaJust saying that bryan may/may not be able to use this info for his/your own good in your program
Jared
Old Feb 9, 2003 | 09:36 PM
97WRAITH's Avatar
sorry don't know what you just said.
Old Feb 9, 2003 | 10:15 PM
atljar's Avatar
i edited my post above, old post in balck, new in red, hope that helps some more
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
alex5366
Feb 17, 2015 09:07 AM
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
Red97LT1
Aug 7, 2002 05:45 PM
