Fuel pump/pressure related...
Old Feb 8, 2003 | 08:10 PM
Greasepunk's Avatar
Anyone know what the stock fuel pressure is?
Also, what are the specs on the stock fuel pump (LPH, max HP supported)?
If say the stock fuel pump supplied (just for arguments sake, not nearly actual) 10 LPH and I bought an aftermarket one that supplies 30 LPH and the pressure was higher, keeping the rest of the fuel system stock, what would this hurt or anything?
Old Feb 8, 2003 | 08:55 PM
c5formetoo's Avatar
with the key on and not running the pressure is between 41-47 pounds.if you put a bigger pump on it will have no negative affects.the regulator will keep the pressure where it belongs
Old Feb 8, 2003 | 08:57 PM
Greasepunk's Avatar
ok kewl, kinda thought so...thanx man
Old Feb 8, 2003 | 09:24 PM
c5formetoo's Avatar
CaptainObviousI
29
Apr 29, 2021 10:35 PM
4586
Apr 24, 2015 01:03 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
tbyrne
Jul 2, 2002 05:37 PM
