Moser 12 bolt axel seals question. work in progress
Old Feb 8, 2003 | 03:37 PM
supermo26's Avatar
I am installing my 12 bolt axels on my 95 LT1. I slid the axels into the tub and lined up the splines. I tapped the axel in all but alittle less than 1/8 of an inch. It has stopped moving. Was I suppost to use the seal with the red edges and the rubber center or was I suppost to toss them. It looks like every thing is correct but the axel will not seat flush to install the brake backing plate. HELP. James
Old Feb 8, 2003 | 04:43 PM
LT1S10's Avatar
Here is a link to a pretty good install page.
12 Bolt install Page
I can't help you more than that, I bought my used and it was completely assembled.
Mike
Old Feb 8, 2003 | 08:21 PM
97 RedSS's Avatar
DId you press the wheel bearing on? It goes on after the back-braking plate..You should put seals inside the axles housings also..
Codyh
Old Feb 8, 2003 | 08:48 PM
supermo26's Avatar
I sent Moser my backing plates and the pressed the bearings on for me. I removed the inner seal and the axel went in with no problem. I did notice that the inner seals were not seated properly into the axel tube. I saw the red colored material was still 1/16 of an inch from being seated. I will attempt to get the rear seals from Moser and try to install them again. (even if I have to pay for them.) I'll try useing something like a big socket to install the seal instead of the axel it self. Thanks for the reply. James
Old Feb 8, 2003 | 10:00 PM
OneFlyn95z28's Avatar
Sounds like you found it. With out those seals the axles will eventually start to leak
Had my axles out yesterday to rebuild Eaton. Got a whoopping 2,500 miles before the Carbon Fiber clutches let go
HectorM52
Jul 30, 2017 11:46 AM
ddr698
Jan 9, 2015 10:05 AM
1LEThumper
Jul 14, 2003 12:45 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
