Pro 5.0 Shifter Question (Already Have one)...
Old Feb 8, 2003 | 03:22 PM
Notford95's Avatar
Hey Guys,
What with the Impala and all, I have a different console setup than you guys. I need to have the Pro 5.0 handle straight up and down. Given a long enough lever, I can attempt to bend the billet steel handle in a vise. Will it break? Should I heat it up first?
Thanks,
Matt
Old Feb 8, 2003 | 03:29 PM
Geoff Chadwick's Avatar
I would personally heat it up first, however you may be better off going to a weld/speed/machine shop of some sort and having them do a custom piece to exactly how you want it. You could bend the handle, but I wouldnt really want to. If I did though, I would heat it to soften the metal.
Old Feb 8, 2003 | 03:35 PM
You might just want to contact Pro 5.0 and see what choices they have available in handles. Since they make handles for the Tremec 5-speed, and the T56 in the Cobra SVO, they may already have something that meets your needs, with the correct bolt holes in it... just a thought.
Old Feb 8, 2003 | 04:00 PM
Notford95's Avatar
Thanks for the replies, guys. I believe Pro 5.0 has a shaft that would work, but that is not economically feasible at the current time. Do you think I would destroy my current shaft by bending it a bit?
Thanks,
Matt
Old Feb 8, 2003 | 05:29 PM
Bud M's Avatar
I heated and bent mine. Worked fine. Put the stick in a vise, heat it up (I used an acetylene welding rig) and put a pipe on the end to bend it with. A shot of spray paint (the heating up will discolor it) and you're good to go.
Old Feb 12, 2003 | 11:33 AM
Notford95's Avatar
Bud,
Thanks! That is what I was hoping to hear.
Matt
Old Feb 12, 2003 | 12:28 PM
ba96ta's Avatar
A friend of mine had the same proublem he took a dremmel and shaved off the notch that makes it stick out. Then re-drilled the holes so the bolts would fit the end product turned out OK but you may be better off bending it.
RUENUF
Mar 13, 2016 03:39 PM
Hoodshaker
Aug 27, 2002 02:32 PM
x7x7
Aug 15, 2002 06:49 PM
jim88iroc305
Aug 13, 2002 09:24 PM
Krab
Aug 5, 2002 12:08 AM
