Hooker long tube screws and installation
Old Feb 7, 2003 | 03:53 PM
Highlander's Avatar
Angry Hooker long tube screws and installation
What screws have you used????
I am having problems with the passanger side and the inner screws. The screws get stuck with the inner flanges of the passanger side...
What do I need??? more patience???
LMK
Old Feb 7, 2003 | 04:16 PM
joeSS97's Avatar
I used Stage 8 locking bolts and didnt have a problem,1 year later I still havent touched em.
Old Feb 7, 2003 | 05:09 PM
IDOXLR8's Avatar
I would also recommend going with Stage 8 Header bolts.
Old Feb 7, 2003 | 05:42 PM
Highlander's Avatar
Where do I get those???
The problem here is not that they get loose.. is that I cant tighten them... My bolts are touching the exhaust tube and I cant get a small wrench in there and I I tried to use allen bolts and I cant get an allen tool in there either... space is too tight!!! too tight!!! too tight!!!!!!!!!
LMK what you guys use and pics if possible...
Old Feb 7, 2003 | 06:20 PM
white97T/A's Avatar
get some bolts with 3/8 inch head - that will give you more room for a wrench - summit has a pack for about $10
Old Feb 7, 2003 | 06:58 PM
Josh'95Z28conv's Avatar
Get the 3/8 head bolts from summit. Thats the only way to go if ya ask me.
Old Feb 7, 2003 | 07:36 PM
Highlander's Avatar
I went to home depot and nothing... If I cannot get them through my muffler shop I will buy them over summit then, if there is no choice
Old Feb 7, 2003 | 07:40 PM
96z's Avatar
96z
I had the same trouble with my ARP 12 points. If it wasnt for my buddy Jason Short and his wrench I wouldnt have been able to get them off. Its a wrench with a real, real thin edge to it. If you got a 6 point bolt it should be too much of a problem to get a wrench in there...
Old Feb 7, 2003 | 09:41 PM
Dr.Mudge's Avatar
I've got a pretty thin 12 point also, on a 1 3/4" tube on these cars its a real PITA.
Old Feb 7, 2003 | 11:22 PM
Highlander's Avatar
I have a 12 face 10mm screw... it doesnt work that well either, the wrenches just dont fit well... I will try and get the screw shaved a bit to see if it helps... I was trying to use allen screws and it doesnt work that well either...
I dont know what to do... I am beginning to hate theese headers...
Its been 2 days to just install them.. I hope I see big gains over my shorties...
This has been a real PITA.
Any other suggestions???
Old Feb 8, 2003 | 12:53 AM
Kain's Avatar
Call up Thunder Racing and have them get you some correct bolts. I have stage 8's, but I had to get the washers ground down a bit to get them by the header tubes.
Old Feb 8, 2003 | 01:14 AM
allmotorta's Avatar
When i installed my ARP 12 points, I needed to grind a wrench down real thin to get a couple of the bolts on the passenger side.
Old Feb 9, 2003 | 11:52 AM
Highlander's Avatar
I was able to put them in... I went to a local speed shop and they had some sets and They went in easier since they were shorter than the ones that I had...
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
RedLineRev
Jan 23, 2003 03:51 PM
