CAM Questions
Old Feb 6, 2003 | 02:26 PM
LALT1's Avatar
CAM Questions
How big of a cam can I use without having major problems. I am changing the valve springs, nut it will be a while before I do any tuning. I would like to go with a CC305 or 6, can this be done with just springs and roller rockers?
Old Feb 6, 2003 | 02:29 PM
notstock4long's Avatar
It can be done, but you might want to port your heads. I have heard that the CC306 runs better than other cams without ported heads because of the exhaust duration, or whatever it is called. you will probably want to get tuning shortly after the cam swap. You can get a tune from PCMFORLESS for under $100.
Old Feb 6, 2003 | 02:32 PM
LALT1's Avatar
Running A4 so I thought that I might would be a little better with the CC305 for that reason.
oldschool
Feb 9, 2016 09:21 PM
chuyz28
Feb 19, 2015 12:50 AM
Brandon Wittmer
Dec 20, 2014 09:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
Noenav
Dec 6, 2014 07:35 PM
