Adjustable stops on Pro 5.0?
Old Feb 6, 2003 | 12:09 AM
96z's Avatar
96z
I was taking a look today at the adjustable stops for my Pro today. How do you know where to set them? Also this may be a dumb question but why are they there anyway just for 3th and 4th gear?
Old Feb 6, 2003 | 12:33 AM
cef97ws6's Avatar
Well someone correct me if I am wrong but stops first got poplular on aftermarket shifters with the T5 because it had no internal stop provisions and when making hard shifts from 2nd to 3rd or 3rd to 4th people were breaking the shift forks. The T56 does have internal stops and shifter stops are not required but can still be used. If you want to use them just put the trans in 3rd gear adjust the stop until it hits the shifter and back it off approx 1/2 a turn and tighten the jam nut. Then do the same for 4th. Hope that helps. Corey
Old Feb 6, 2003 | 01:03 AM
Prince's Avatar
Re: Adjustable stops on Pro 5.0?
Damn Sir post's Alot!!!!!!! When I come over to do the wiring, I'll help you (yet again) with it.
Dave
Old Feb 6, 2003 | 10:32 AM
96z's Avatar
96z
Yeah my post count is getting a little embarassing I guess. 'Just got a lot of important questions to be anwsered.
Oh and thanks again Dave.
Old Feb 6, 2003 | 02:04 PM
Laymaster's Avatar
yeah what the other guy said. Just make sure you really tighten that stop nut, I didn't make mine too tight and it wound up loosening and backing off some, which kept pushing me out of third gear....you don't want that.
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
