strange problem w/ motor swap
Old Feb 5, 2003 | 11:38 PM
JD95BIRD's Avatar
Unhappy strange problem w/ motor swap
okay here's whats happening. I removed the orig LT1 and I am building it and after I removed it I found a 94 Imp SS motor. I bought it and to this point everyhtings worked great, motor runs awsome runs very strong and sounds good. My problem is the harmonic balancer(which is from the orig motor) sticks out about 1/2 inch past the tensioner. In other words it doesn't go back far enough and as soon as the motor is turned over the belt walks to the back of the balancer(toward the motor). I've tried both balancers same thing. Is the actual hub or whatever, that is on the crank that the balancer bolts to different between the motors? I have the original one in my garage. Does it need to go on if so how do I get the old one off and the new one on? If I don't have to do this what do I do to get the balacer lined up. Please help anyone as soon as this is fixed my car is back in business!
Josh
Old Feb 6, 2003 | 12:58 AM
Trans-Am's Avatar
Make sure the HUB that is behind the balancer is completely flush with the crankshaft snout. Pull things apart, do some investigating it has to be obvious once your tear into it. ~~~rob
Old Feb 6, 2003 | 01:03 AM
bad95z28's Avatar
i agree, it would almost have to be in the hub. but, this is the first time i've ever heard of this and it seems a little weird. the belt is coming off by itself? are you sure you have the right size belt?
Old Feb 6, 2003 | 08:28 AM
JD95BIRD's Avatar
Yea its the stock belt that came off of it. never had a prob before. What is the best way to remove/install that while the motor is in the car?
Old Feb 6, 2003 | 08:37 AM
bad96firechikin's Avatar
It is the hub. I swapped the motor in my car once before, and someone before me had used a '93 - '95 crank hub on it, and it was a '96 or '97 engine with the reluctor ring for the crank position sensor, and it stuck out a 1/2 inch too far. The '96 and '97 hub is about 1/2 inch shorter than the one used in '95 and earlier, and it is because of the crank position sensor added in '96. This, however, leads me to believe that you're engine is out of a '96 Impala. Try the shorter crank hub. I've got one if you wanna give it a shot. This sounds exactly like the problem that I had with mine though.
Old Feb 6, 2003 | 08:45 AM
BTW, easiest way I've found to pull it in the car, is to first remove the crank bolt, and leave the balancer on. Find a long bolt (about 4 or 5 inches) that is much much thinner than the hole in the crank snout. Make sure it is grade 8 (I've heard people tell horror stories about a bolt collapsing into an 'S' shape inside the crank). Get you balancer puller, position it at the end of the bolt you've placed in the end of the crank, and use the 3 small bolt holes on the BALANCER (not the hub, and not the bolts attaching the balancer to the hub) to pull it. If you need more room to fit a wrench on the end of the puller, just slide the cooling fans up. Good luck.
Old Feb 6, 2003 | 09:31 AM
DeezT/A's Avatar
hang in there bro, you'll get it one day
dustin
Old Feb 6, 2003 | 05:09 PM
JD95BIRD's Avatar
Okay weird as this seems I do not have the 3 puller holes on my stock balancer so how do pull it off other than using the hub holes? Also I have the stock hub off my car what is the best way to put those on while in the car, a rubber mallat?
thanks
Josh
Old Feb 7, 2003 | 08:44 AM
JD95BIRD's Avatar
Anyone? I really would like the best way to put on that hub. Is ti just Lining it up and going at it with the ruber mallet or what?
Josh
Old Feb 7, 2003 | 09:36 AM
Josh
The best way is with an installation tool. It is not recommended to hammer it on. A mallet is not going to be enough to get it on. Don't use the bolt to try to pull it on. You will risk stripping the crank threads. Look at Summit or Jegs to see what a tool looks like. Some people have made their own, using a piece of threaded rod, a plate and a nut or two.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ModdedNerd
Jan 29, 2015 07:23 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Brandon Wittmer
Dec 7, 2014 12:15 PM
