lingenfelter 58 mm TB adjustment questions..
Old Feb 5, 2003 | 08:18 PM
97SS ragtop #077's Avatar
i have a 58 mm lingenfelter tb...
2 questions i need help with:
1) how exactly do i adjust the TPS?
2) how do i determine how much i should manually "crack" the throttle blades open ?
TIA to all replies!!
Jeff
Old Feb 5, 2003 | 10:00 PM
Adjust the blade stop screw slowly to achieve the correct correct idle speed, making sure the IAC count is in the range of 20-40. Then check the TPS voltage. The stock PCM will accept any closed throttle TPS reading between 0.20-0.90V, and baseline that as 0% throttle position. Some people seem to feel they get better results with the TPS voltage in the range of 0.50-0.65V, so you can try slotting the holes in the TPS sensor to allow it to be rotated slightly.
Old Feb 6, 2003 | 04:30 PM
thanks much....Jeff
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
SEOJustin
Sep 24, 2015 04:39 PM
95craz28
11
Sep 12, 2015 07:47 AM
