grinding going into 3rd an 4th
Old Feb 5, 2003 | 03:36 PM
98whiteZ28's Avatar
well my car doesnt do it but my friends 2000 trans am does he says its from "slamming" the gears so much from racing and what not but i dont see how that could be? anyone else ever have this problem, and what could be causing it??? just some curiousity
Old Feb 5, 2003 | 04:10 PM
steelerfan's Avatar
Sounds like syncro going bad
Old Feb 5, 2003 | 08:10 PM
kjlvilla's Avatar
Speed shifting your manual trans. is about the worst thing you can do. It doesn't give the synchros a chance to get both gears at the same speed allowing a smooth engagement. It also can bend shift forks, which will cause a jump out of gear condition. Your friend is right, he caused his own problem.
Old Feb 5, 2003 | 09:40 PM
98whiteZ28's Avatar
He also says that after he gets his 4:10's put in that the grinding will be gone?just wonderin if thats true too?
Old Feb 6, 2003 | 03:36 PM
steelerfan's Avatar
Sorry,but that won't make a bit of difference.The trouble is in the trans,not the rear
David Dempsey
Mar 12, 2016 12:42 AM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
4586
Sep 27, 2015 01:55 PM
