fmu questions
Old Feb 1, 2003 | 10:46 PM
2turboz28's Avatar
fmu questions
i need to know if there is a formula to figure out the rising rate of the fmu that a motor requires.
Old Feb 1, 2003 | 11:10 PM
FireAm94's Avatar
Just buy larger injectors..not much more and will be much more tunable.
Joe
Old Feb 2, 2003 | 01:56 PM
2turboz28's Avatar
i think that i should need more than injectors if i am runnin around 20 psi from a turbo. i just want to know what i should run for a fuel cuve with the fmu. i figure that 6-1 should be plenty, but i dont wnat to be to lean on the top end!!!BANG
Old Feb 2, 2003 | 06:52 PM
FireAm94's Avatar
Guess it's carburated too eh? Just noticed it's a 1980.
Old Feb 2, 2003 | 09:19 PM
2turboz28's Avatar
no its for the six. i havent finished the twins yet. the 6 blew a head gasket so i decided to go all out with it and see what type of boost levels i could run on the stock block and crank. if i blow it up because the block doesnt hold or the crank breaks, then ill get a nice block or one of those g/n race blocks.
Old Feb 4, 2003 | 05:47 PM
toykilla's Avatar
Yea...just hope when you snap one or all of those rods they don't fly upwards and take out your hood, intake manifold, cam, rockers, springs, and all that good stuff. Your be looking for a bit more than a block then...
Your gonna be running 20psi daily or is that track boost? That's insane if your doing it daily, have fun paying for fuel every day just to get to work and back...
Old Feb 4, 2003 | 05:57 PM
2turboz28's Avatar
its going to be 8 psi around town, and around 20 at the track! for the first couple of months i am going to take it easy though, prolly only run 10 max. i want to see what the motor will handle, and there are people that are running 13's on 8psi and a stock motor and fuel pump. i am getting a custom cam and forged pistons, with alot of the other stuff you need to run boost on safely. as far as driveability goes, this is the wifes car, so she wont be on it that much. but if she does get on it too much, then she has to pay for gas. 8psi is fine for the street.
drptop70ss
Mar 26, 2015 01:50 AM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
SC97TA
Sep 15, 2002 01:10 AM
