What RPM for shift light?
Old Feb 1, 2003 | 04:21 PM
kgkern01's Avatar
Just got my Harlan shift light in. What RPM should I setup my shiftlight for? Besides bolt-on's my car is stock. Also what is the stock rev-limiter set at? And What wires did anyone plug theirs into?
Old Feb 1, 2003 | 04:34 PM
kgkern01's Avatar
Old Feb 1, 2003 | 04:46 PM
teke184's Avatar
i set mine for 5900, i beleive the stock limiter is 6k...so that lets me shift just before the limiter kicks in...
experiment, set it for 5900, see if you hit the limiter, if you do, back it down a bit.
Old Feb 1, 2003 | 04:53 PM
kgkern01's Avatar
Which wire do install for the RPM wire? Red is for the positive turn-on, the black is a ground, and the green is for the tach, which wire on my car do I connect this to?
Old Feb 1, 2003 | 04:57 PM
gb95zconv's Avatar
Stock limiter is 5800.....so youll need to set it at 5700. Get some programming software and move your limit up. I wire mine into the tach wire going to the insturment cluster.
Old Feb 1, 2003 | 05:00 PM
maserati82's Avatar
Check Brent's site under the alarm install for the tach wire. I believe its a gray wire coming off of the PCM.
Old Feb 2, 2003 | 09:08 PM
kgkern01's Avatar
Installed thanks for the help, I don't have LT1 Edit or any other programmer to adjust my rev limiter, set it at 5800 tried a few runs and hits rev limiter right as I shift, so I think I'm going to drop it down to 5700 so I don't hit the limiter. D*mn limiter
Old Feb 2, 2003 | 09:35 PM
atljar's Avatar
White wire, red connector on PCM, pin #13.
Stock rev limiter is 5750.
No reason to tach the car out that high. Stock cam stops making power at 55-5600.
Try running at the track taching it all the way out, then shift at 5500. Garantee you will go fater on the 5500.
Old Feb 3, 2003 | 12:04 PM
kgkern01's Avatar
Thanks About to go out and adjust and try again.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
phantasm99
Aug 28, 2002 11:01 PM
Brady
Jul 29, 2002 10:30 PM
