12 bolt users got a ???
Old Jan 31, 2003 | 08:29 AM
Smoke T/A's Avatar
I have a moser 12 bolt and i have stripped out the U bolts that hold the driveshaft in place. Where can i get replacment bolts? Thanks in advance.
Joe
Old Jan 31, 2003 | 09:36 AM
rskrause's Avatar
Moderator
Re: 12 bolt users got a ???
Joe
Moser. Or Denny's Driveshaft at http://www.dennysdriveshaft.com/ Great service from them in the past.
Rich Krause
Old Jan 31, 2003 | 11:18 AM
DaveW 396ci's Avatar
I would expect any parts store should be able to help you out. If not then call up some drive train specialists in your area. No real reason to wait for mail order to show up.
DaveW
Old Jan 31, 2003 | 01:05 PM
Smoke T/A's Avatar
Thanks I picked some up at a local shop for $7.00
Joe
Old Jan 31, 2003 | 04:36 PM
SStupid's Avatar
Moser
I just read a thread warning Moser 12-bolt rearend owners to check the length of your driveshaft. Supposedly, your driveshaft will have to be shortened. Moser does not divulge this information. Damage to tranny will result.
Old Jan 31, 2003 | 05:07 PM
Smoke T/A's Avatar
Re: Moser
Well thanks for the warning but i swaped in the 12 bolt and a TH350 at the same time and ther is no way the stock shaft would have worked. I had a custom one made to fit my application. Pretty much common sense when changing the rear or trans to check the correct lenght of the drive shaft.
Joe
Old Jan 31, 2003 | 06:18 PM
kirschman's Avatar
humm..... mine has been in for over a year now and no probs at all. I checked my DS length before install and measered out ok. Where did you read this at, I would like to see for myself.
Old Jan 31, 2003 | 08:51 PM
97 RedSS's Avatar
Where did you see the DS needed to be checked? Mine fit perfectly..
Cody
Old Jan 31, 2003 | 09:09 PM
OneFlyn95z28's Avatar
Don't you just HATE it when they do not give ALL the info
IF you got a Moser with a 1350 Forged Yolk you will need to shorten you DS 1/2 inch.
IF you got your Moser with a STOCK yolk you will be fine
Victor Lamb
Aug 26, 2017 02:52 PM
QuickSilver02
Apr 7, 2015 11:12 AM
maybe2fast
Mar 16, 2015 09:45 AM
95chwagon
Feb 28, 2015 12:02 PM
Jlo
Feb 3, 2015 09:41 PM
