what is the strongest yr for the LT1's
Old Jan 30, 2003 | 10:15 AM
DFISH's Avatar
ok i have heard that some yrs of the LT1's are better than others so which yr is the best for the LT1? b/c i am thinking about buying a 1995 is that a good yr??? well thanks
~David~
Old Jan 30, 2003 | 10:35 AM
thelategreatz28's Avatar
the 93 is the strongest year for the camaro, it doesnt have any airflow restriction and stock its 300 hp!
Old Jan 30, 2003 | 10:39 AM
'94 Bad A Z28's Avatar
This can be a big argument... Most people would probobly say the '95... It had a little more power than the '94 and '93, and it was the last year of OBD-1. If you look around, you will notice that a lot of OBD-II cars are converting to OBD-1.
Old Jan 30, 2003 | 10:41 AM
What crack pipe are you smokin'?!?!?! 300 hp? Since when, not in '93...
Old Jan 30, 2003 | 10:46 AM
Silver Z28's Avatar
I hear a lot of people say the 95' is the strongest but logically you would think it would be the 97' because after 5 years of producing the LT1 you would think all of the kinks would have been worked out and most performance squeezed out.
Old Jan 30, 2003 | 10:49 AM
chesee48's Avatar
yea i agree....u would think the 97 would be up there...
Old Jan 30, 2003 | 10:52 AM
GREGG 97Z's Avatar
Yeah, didn't you know that all 93's came stock with a CAI package, 58 MM tb, and LT4 heads???
Old Jan 30, 2003 | 11:15 AM
IDOXLR8's Avatar
This topic has being discussed greatly. If you do a search you will find alot of good info.
The question as presented is barely worth asking. You could probably line up all years, side-by-side and depending on driver, there would not be a car length between them all at the end of the quarter mile.
There are more things to consider like:
speed density vs. MAF
4L60 vs. 4L60E (in cases of A4)
M28 and M29 vs. MN6
OBD1 vs. OBD2
non-vented opti vs. vented
It all depends on how you want to massage the car and what road you want to take to reach your goals. There are advantages and disadvantages to all. The best bet is to read up on all years and decide for yourself.
Old Jan 30, 2003 | 11:58 AM
Lol... Oh yeah, DUH!!
Old Jan 30, 2003 | 12:51 PM
Mikey97Z's Avatar
I think the 97 was rated at 285hp stock, a 10hp improvement due to the dual cats.
Old Jan 30, 2003 | 12:53 PM
syacoub's Avatar
Yup, you're correct, 285hp stock and definitely due to the dual cats. I'm currently driving a 1997 camaro Z28.
Old Jan 30, 2003 | 12:57 PM
DubbyZ28Camaro's Avatar
How does dual cats gain 10hp??? That is just a restriction in the exhaust flow. Why do you think most people (that are able to) REMOVE their cats to get a little more performance???
Old Jan 30, 2003 | 01:01 PM
turbo_Z's Avatar
you would think 97.
-last yr of the LT1...all the bugs gotta be worked out by then
-dual cats...freer flowing exhaust
-*recently discovered*....heads flow a little better
-OBD2....might argue it manages fuel more efficiently than OBD1. pure speculation
-new tail lights and interior...hafta be worth 5 ponies at least!
Old Jan 30, 2003 | 01:04 PM
turbo_Z's Avatar
pushing less exhaust thru 2 smaller cats is freer flowing than pushing ALL the exhaust through 1 large cat.
