CC306 help please
Old Jan 29, 2003 | 11:08 PM
LT1derful's Avatar
CC306 help please
Guys. Everyone talks about this cam. Comparisons to the XE cams and such make locating the XE cams easy...but everyone calls this cam, CC306.
Far as I can tell, no one sells it as the CC306. What's the part #, grind #, or how to I identify the CC306 when browsing say Jegs or Summit?
I want #s on this cam so I can compare it around a little better. Right now, eye is on XE 236/242; or Comps 290HR-12 which is 230/244.
Thanks for the help.
DJ
Old Jan 29, 2003 | 11:15 PM
LT1derful's Avatar
Also...what's the largest lift we can handle on stock heads?
DJ
Old Jan 29, 2003 | 11:58 PM
Trans-Am's Avatar
If you turn to the "TPI-LT1,LS1 section of summit and look at the cams. You will noitce that the number for the "CC306" will be 07-306-1074 or something. I just ordered mine recently. Specs are in the catalog. Try a search on this board that usually helps. have fun!!!~~rob
Old Jan 30, 2003 | 12:04 AM
LT1derful's Avatar
THanks bro. I tried the search first, always do...but couldn't find specs or part/grind #s.
You've helped a lot!
DJ
Old Jan 30, 2003 | 12:19 AM
Camaro37's Avatar
specs are 230/244 .544/.576 w/ 1.6 RR 112 LSA
Old Jan 30, 2003 | 12:20 AM
LT1derful's Avatar
LOL...while I couldn't find any cams under TPI/LT1/LS1 except Lunati LS1 cams.
I FINALLY found online the CC306 specs.
Seems the Comp 290HR-12 is the CC306; 230/244 duration .510"in .540"ex @ .050" 112* LSA
Cam looks good on Desktop Dyno!
DJ
mightymouse383
Jul 20, 2016 07:34 AM
Z Power
Sep 19, 2015 11:19 PM
Abdullah
Feb 6, 2003 06:23 PM
turbo_Z
Jan 31, 2003 09:45 PM
James3219
Jan 30, 2003 12:01 AM
