A/C Hose - Anyone know the GM part #?
Old Jan 27, 2003 | 10:31 PM
bad96firechikin's Avatar
Ok, I kinda sorta forgot to tie back my rubber line coming off of the A/C compressor, and the alternator fan chopped a pretty good sized hole in the hose. Lucky for me I hadn't put a bit of refrigerant in the lines since I broke them loose, but I'm still faced with the problem of finding and replacing this hose. I need the GM part number. If i get one correct responce to this thread, than I will be forever greatful! THanks guys!
Old Jan 27, 2003 | 10:36 PM
Pick the item number from this view and I will try to dig up a parts number for you.
Old Jan 27, 2003 | 10:41 PM
I believe it's # 29, should be a whole hose assembly - a hard line running from the compressor to the condenser, and a long rubber line.
Old Jan 27, 2003 | 10:44 PM
Gotta hit the hay, work in 5 1/2 hours for me. I'll check for ur reply in the morning. Thanks shoebox!
Old Jan 27, 2003 | 10:48 PM
I thought that might be the one. GM PART # 10269542 for your 1996. It is the whole double pipe assy and includes 24, 26, 27 ,30, 32, 36, 37.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
pologreen97z
Dec 2, 2014 10:42 AM
