A/C Hose - Anyone know the GM part #?
Ok, I kinda sorta forgot to tie back my rubber line coming off of the A/C compressor, and the alternator fan chopped a pretty good sized hole in the hose. Lucky for me I hadn't put a bit of refrigerant in the lines since I broke them loose, but I'm still faced with the problem of finding and replacing this hose. I need the GM part number. If i get one correct responce to this thread, than I will be forever greatful! THanks guys!
Pick the item number from this view and I will try to dig up a parts number for you.
I believe it's # 29, should be a whole hose assembly - a hard line running from the compressor to the condenser, and a long rubber line.
Gotta hit the hay, work in 5 1/2 hours for me. I'll check for ur reply in the morning. Thanks shoebox! :bow:
Originally posted by bad96firechikin I believe it's # 29, should be a whole hose assembly - a hard line running from the compressor to the condenser, and a long rubber line. |
